turbodave231
Moderator
- May 24, 2001
Take a look at the pictures of my rod bearings. I had the engine out and I figure I might as well look at the bearings.
The engine probably has 25 passes on since new. All 6 bearings had the same pattern to the bearings. No grooves, no real damage. But you can see the load has been on the outside of the bearing shells. Is this normal for an offcenter motor?
Engine specs: Carrillo 6.5 offcenter rods, Clevite 77 V series wide rod brgs .0019 to .002 clearance. Great oil pressure, no problems, just looking to be sure......opinions?
rod bearings
rod bearings
