oil came out of the exhaust side of turbo when i blew my head gasket.
bpman1234
hey fellas whats going on ? just want to know if i can use the turbo again cause it wasnt leaking before the gasket gave .is it normal fo the oil to come out the exhaust side of the turbo when you blow a head gasket ? thanks in advance .
Same thing is happening to me on a new engine install.
If you pressurized the crankcase its possible that you inhibited oil drain back.
I just installed an RJC pcv and gained this leak. I hope its just a faulty valve. It only leaks under boost and its draining down the housing. Hope I remedy my issue going Back to my old pcv setup.
Your old PCV won't matter. There's no positive flow when there's boost.
So if my pcv is allowing boost to bleed by the back pressure wouldn't cause the blow by?
