Here is my opinion and experience on using an engine flush in a turbo Buick, I doubt that it is really needed, especially if it has had normal and routine maintaince.
After seeing the insides of 1000's of these engines there never has been any large amount of sludge like many of the olds cars had.
If you did use the flush, there would not be any issue of clogging the PU screen or anything else if the proper procedure is used since the crud would be in suspension and drained out.
One case comes to mind, years ago we purchased a used truck for our fleet and found it was full of sludge. First we ran flush through it and drained it. We then poured a gallon of gas in the oil fill with the drain plug still out, and a while later poured a gallon of oil through it. Installed the plug, filled it with oil and it was in service for a few more years.
In the 90's and later vehicles, computers and fuel injection along with unleaded gas, and oils with more detergents made engine sludge a thing of the past.
Look into your oil fill hole in the valve cover, and you should be able to see if there is any sludge built up.
