OIL COOLER ADAPTOR
Do you know which one fits ? What adaptors do I need for the hoses ? I am not sure if the factory adaptors will work with this one.
To be honest, I don't know since I was going to use the oil filter type of oil adapter(http://www.glowshiftdirect.com/Oil-Filter-Sandwich-Adapters.aspx) for my oil pressure switch, but then decided another avenue, and I didn't get a chance to use it.
In your situation you might want to start a new thread and ask what size are the oil cooler thread size and go from there?
Do you know which one fits ? What adapters do I need for the hoses ? I am not sure if the factory adapters will work with this one.
Curiosity, what was the hose size fitting for the oil cooler adapter you got. Thanks
I'll post back here with a size once I get it. I called tech help twice and they had no clue...go figure !!!!
I have it installed and works perfectly. There is enough room in the housing that you can drill and tap the exsisting lines out and tap them for 1/2 pipe threads. You can then use the fittings from the stock oil cooler adaptor. If you are using the RJC biggie oil filter adaptor, you will have to make a new adaptor, as the RJC one will not work.
I have it installed and works perfectly. There is enough room in the housing that you can drill and tap the existing lines out and tap them for 1/2 pipe threads. You can then use the fittings from the stock oil cooler adapter. If you are using the RJC biggie oil filter adapter, you will have to make a new adapter, as the RJC one will not work.
Thanks for the reply of the fitting is 1/2 pipe threads.
Are you using this for an external oil cooler? If not then for what?
I am still using the factory cooler that runs through the radiator.
Which filter adaptor did you end up getting?
I just broke mine and need to replace it.
If your going to use a bigger filter the RJC adaptor will not work. If you plan on using the stock size filter, order the one with the 18mm x 1.5 thread.
what did you do about the oil pressure sender port? on my car theres a sender on the filter housing on the engine, did you have to just plug that 3rd hole?
what about the in/outlets? i converted my lines to an already so hopefully the adaptors that come with it should work
The billet adaptor comes with two pressure ports, they are 1/8 NPT. Oil line fittings are 10AN
