So I got my motor in the car and all is good except one minor thing. Runs awesome and is turning out to be a pretty scary car at various points in the throttle. One problem tho. I have a leak from the back of my oil pan between the pan and the girdle where the gasket is. I took it to my machine shop that assembled the motor and they found the leak. So before they tightened the pan bolts a little they cleaned the oil off and let the car run at idle for a bit and no leaks. Put it in drive with the break on and brought the rpms and boost up and as soon as they got a couple lbs of boost it began to seep. So they tightened it and did the same procedure and no leaks. Well than they took it for a drive and boosted it to see what would happen after a couple of mins of driving and after it was back on the lift it began to drip very slowly and much less than before. So the verdict is that under boost my crankcase builds pressure enough to push oil out of the back of the pan. Any remedies to cure this crankcase pressure? I have a regular breather on the valve cover and a brand new PCV valve. I think for some reason I have seen kits to fix this crankcase pressure but but cannot remember. Anyone have an ideas? Oh and please remember I am broke after my tranny and motor rebuild!! Thanks
-Andrew
-Andrew
