I looked at every option and just cleaned it as the previous post suggested. I could not find any way that would not damage it.Looking for any ideas on how to remove oil filter bypass from the filter adapter without destroying it. I want to put it back in after a cleaning.
Thanks in advance
Are you talking about the adapter that connects to the hoses that lead to the oil cooler in the radiator ? If so all you do is get a socket that fits around the center I believe it’s 3/4 or 15/16” and remove the center piece that’s holding the adapter plate on
Copy that .its still pretty straight forward to disassemble and cleanHe's talking about the plunger/spring assembly inside the adapter, not the adapter itself.
what are those pictures
