You can install breathers, baffles and catch cans to trap as much of the oil vapors, but that is just a band aid. As you move on to more boost and HP to bring you into the 10's, it only gets worse.
The ultimate solution starting at that level, is to have a pump to evacuate the crankcase vapors [pressure] and vent them properly.
This can be done with an electric or belt driven pump. When you reach a power level into the 9's, a proper evac system will also add a little HP.
