I have been trying to find this leak for some time now and I finally have. It is leaking from where the line connects to the turbo. Its the line Johns performance. Ill try to describe where exactly it is. The piece that bolts to the turbo that you screw onto the return line is the source. I took off the return line from the turbo and tried screwing it on farther, it wouldnt really budge. So I connected back on the turbo and now it leaks even more, its like a steady stream
. Should I take it back off and put some sealant on it? If so what kind?
