I noticed I had an oil leak coming from the passenger side valve cover on my GN. I pulled the cover off, noticed a cork gasket, so I removed it. I cleaned up the mating surface and replaced the gasket with a Fel-Pro rubber one. I put everything back together, tightened all the bolts, cleaned up the residue and went about driving the car.
I noticed again that it is still leaking from the same spot. Is it possible that my valve cover itself is tweaked and won't allow the gasket to seal? I inspected the valve cover for cracks when I had it off but didn't see anything out of the ordinary.
Idea's? Leads? Any help is greatly appreciated - I hate parking on cardboard.
