DarthBuick
I Win even in your dreams.
- Dec 22, 2014
I have a pretty bad oil leak. At first I thought it was the pan and replaced the pan gasket with a Cometic. It was still leaking and I found it to be leaking down the front. The oil is tracking down the front by the lower crank sensor bolt.
It is a pretty bad leak when running. Could it be the valve cover running down. front seal is dry and fuel pump block off plate seems dry.
