Some Loctite Blue 242 on the valve cover bolts helps a lot.
After you clean out the holes with a little carb cleaner or degreaser.
The PCV was created in the mid 60's or 70's to address emissions/ EPA issues about crankcase vapors leaking into the atmosphere.
So - the idea? How bout we run in back through the engine and (try to) burn it?
After just having chased this PCV leaking issue for a week or more - Trust me - most of them leak at even low boost levels.
Depending upon the crappiness level of the brand of PCV.
You'll be surprised at how much boost they leak - and that 11/32" line flows pretty well.
That can't be good.
I ran a full boost test on my entire intake, inlet bell to the TB - and I don't want leak a single molecule of good boost.
And I found plenty of molecules leaking in various places.
If you're going to run a PCV - then I would definitely run an $6 inline 3/8" check valve.
But a catch can is far superior to evacuating the crankcase and keeping the junk out of the intake.
Pull your vacuum block if you want to see even a hint of what is being sucked into your engine's intake.
Trust me - it will be oily underneath.
Some - very oily.
My simple PCV tester is below.
And my not so simple boost tester.
