If I recall correctly, most of my reinstall problems had to do with clearance around the front counterweight on the crankshaft. Try rotating it up out of the way.
I also recall unbolting the front motor mounts so I could raise the front of the block and gain clearance between the block and the crossmember.
Good luck,
Buzz White in Houston, TX (sumnerw@flash.net)
