I'm with lazaris and Lonnie. I have had two cams go flat (not so budget rollers), and if it weren't for the blocked bypass I would have been in a world of hurt. It saved the bearings and turbo.....twice. I run 15-50 with about 60psi on cold start ups and 20-24psi at idle.
I have had a PureOne filter collapse on me. I have had zero failures with AC filters though. I run a biggie conversion too. You should be okay with a large filter on your relocation kit. It's cheap insurance for a motor that is known to eat cams, front cam bearings, cam trust surfaces, and the occasional trust bearing due to ballooned converters
