Oil pressure sending harness
Status
Not open for further replies.
Bobtempest
Moderator
Staff member
My oil pressure sending unit harness has pulled one of the wires out of the harness. Anywhere you can get a replacement plug? Its the harness right bellow the oil filter.
Rob
[Bobtempest]My oil pressure sending unit harness has pulled one of the wires out of the harness. Anywhere you can get a replacement plug? Its the harness right bellow the oil filter.
Rob
Yes and Yes! Try Caspers Electronics http://www.casperselectronics.com/
(847)247-0484. Give them a call 1st and tell them what you need.
Connector
Locally your Delco dealer should have a PT121 available... or use 12085499 at any GM dealer. You can see the image of this connector to make sure its right for you by going to:
http://whttp://www.acdelco.com/html/catalog/index.htm .. then click "Dsplay Image by AC DELCO Part Number".. Enter PT121.. Check that its the part your after.
They are around $30 rtl. See if that also helps you.
Ozpont... great link.. and yes thats the one.
Status
