Oil pressure Sending Unit Screw Size
chris romani
member
TurboBuick.Com Supporter!
Does anyone know the Screw Size for the Power Wire with the Small Eyelid for the VDO Oil Pressure Sending Unit and Temperature Sending Unit.My Motor came back with these 2 Screws gone and I need to Replace them.
Where are the two screw holes that are missing screws? From the picture there is a threaded hole in the black plastic nut. This black plastic nut is a finger tight nut that holds on the single sending wire to a gauge.
Where is the temp sending unit?
Oh ok so your saying the black plastic nut with the threaded insert I take off and put the wire on the small stud behind it and Screw it back in.
