oil pump gears
87-TURBO-T
I had an extra timing cover apart for a while now and have a question about the oil pump gear (without the shaft of course). it has a mark on one of the teeth, does it face up toward the water pump or down toward the ground? thanks
I install them sideways.;) Actually I don't think it even matters. I also install then facing down (when in the car) because it seems the right thing to do, but it is a straight gear, so it shouldn't matter.
I dont even know why they have the dots? maybe for reference marks so they do go on the same side? Probably not a huge issue anyways.
