A dry pump will never be able to create the suction needed to pull the oil up. Need oil, assembly lube or something.
Next time? Why would the pump ever lose prime? It surely doesn't lose prime from jacking the car up. There is another problem.
Rick,
Like I said: I respectfully disagree, because my real life experiences are different.
My experience #1 of many;
I recently installed a TA cover, assembled with some GM EOS to lube the stock size gears and shaft. No added oil in the pump, PJ, blah blah. 5 Quarts of 10/40 in the pan, filter pre-filled with EOS and non synthetic 10/40. Ran a cordless ~600 rpm drill on the priming tool in CW direction only, and within 10-12 seconds, saw 60 PSI on my dedicated mechanical priming gage. I have actually successfully repeated this process quite a few times with various covers, from factory installed, over the counter, and now my TA unit.
The fact is: The engine lost prime, and shouldn't have. Even than, it should have primed right back up cranking, drill priming, starting, blah blah.
What we agree on;
SHOULD not have lost prime and something is wrong.
What we will need to agree to disagree; "I" will never be convinced to add the PJ crutch to prime any engine, if it lost prime sitting on stands.
