oil pump?
guys thanks for all your input will drop pan and replace oil pump tuesday will let you knew what i find back on this page thanks again.
just got done the new pump kit fixed it oil press much better now any one that has to do this to your car petroleum jelly is a must to prim the oil pump just like someone said on the board thanks for all your help will keep a eye on it for a day or two but it looks tobe fix now .
Glad to see you got it fixed and the vasaline worked for you , that seems to be the only thing that works.
Good job.
Not to get too much off the subject, but I bought a high volume oil pump a couple years back to install on my last GN. I now want to upgrade the oil pump on my new GN. Am I correct in my recolection that TRW makes a high volume oil pump. If I'm wrong, what is the pump upgrade of choice?
Thanks,
Tim
Melling makes a nice high volume pump. They're really not needed. I have one just because my old front cover was bad so I bought the high volume one. Bead blasting the gears helps noticably too. I believe the melling kit is about $30.
