Oil Return to Pan - Hot Air Block
Nocooler
Had a Hotair
Any Recommendations?
I was thinking -12AN line with a bulkhead fitting in the pan. Any other options for the pan? I'll need a flange for the bottom of the turbo also - I've used T-netics' in the past the threads were junk.
Nocooler
I have used -10 fittings/line for a pan oil return. Probably more leak-free to weld the fitting to the pan. It will fit fine at the front of the pan and use a 120 deg. fitting to angle up towards the turbo.
Originally posted by Nocooler
Nick - where can I get a steel fitting to weld to the pan?
Jeremy
Try a place that sells or fabricates commercial hoses/fittings. Maybe big truck parts house?
pan
You could weld a .500 or a .750 pipe coupling to the side of pan and use a pipe to hose adapter. Might be easier to weld a coupling. Just a thought. It would need to be a steel coupling -not a cast piece.
