I have a few questions here, and hope some of you may be able to help. I also posted this in the Hybrid section.
Can a 109 block be dry sumped? May not be practical, but is it possible? Approx. how much for this setup?
I have a remote mount oil filter setup. This has 2 outlets. I was going to use one outlet for a guage, then the other to go to an oil cooler, then back to the adapter at which point, i'm going to install a tee. The tee will have an -12AN to -04AN reducer. From here I will split this using an NOS Y-block. Each of the -04AN outlet will go to each turbo.
Turbos
Cooler. ______|_______ Motor
Is this setup going to provide enough oiling for the 2 turbos?
Fuel system question. I am planning on running 10AN supply 6AN return. Fuel pump Aeromotive A1000. Think this would be suffiecient for 700hp?
Thanks for your help!
Turbos
