- May 28, 2001
If this post gets deleted so be it but I am getting sick of this bull****.
These are my observations having used a FAST system for about 18 months now.
Pros
The FAST system is a definite step up from a batch fire DFI, which was all there was unless you wanted to pay $10,000.00 for a MOTEC.
The ability to datalog just about any engine parameter you want is a great help at the track, dyno or even on the street.
The Wideband O2 sensor is definitely a very good tuning tool and takes the guesswork out of tuning the fuel map.
The Windows features that are built in make it just that much easier to use the program. It is pretty much a straight forward deal if you have used any kind of program to tune with prior to now.
Any time you can go to the track, datalog the run, analyze it and make informed decisions you are way ahead of the game from when Buicks first were intercooled some 17 years ago.
Cons
I am fully aware that the WB sensors will not last for an extended period of time. That is just the nature of the beast and it is accepted. What makes this so difficult is that in order to get a new sensor, you must send the unit back to FAST and let them calibrate a new sensor to your ECM and then it is sent back to you.
This is prohibitive in terms of cost ( even though when you say Buick it costs 3 times as much) and time lost because the unit must be sent back. At the very least, FAST should be able to send out a new sensor and calibration disk to the end user to reduce the amount of time this takes.
I do not like the level to which FAST deems it necessary to keep their product proprietary.
Software.
I have a software problem in my program as well. I am not seeing the random number problems others are. I do have a problem where I cannot adjust any trigger to commence datalogging on the computer. It seems stuck no matter what I do. The only way I can log at all is by using the manual trigger and that does work.
This is a case in point of why I, as the consumer, should not have to pay an additional $30 for a newer version of the program just to fix a problem that should not be there in the first place.
Of course I called FAST and their answer to my dilemma ( in essence) is " That will cost $30. It should not cost me a dime for a defective program. I should not be charged shipping for it either. There should be a software fix sent to me so I can use the product the way it was designed and assured it would function.
If you have customers informing you that the software you have designed for the system that you charge $2500 to $3500 for you should absolutely be proactive in getting a software fix out to ALL of your customers immediately with any hesitation, complaints or denials.
Rather if you see posts up on this board about software problems you should be making contact with them and finding out how FAST can make their customers happy with the defective product you just sold them. I dont care if the product was purchased through a vendor or directly through FAST ( which I know does not happen but I am using this as an example). Your company relies on the orders from your vendors, if their customers are not happy then market dynamics dictate that they will take their money elsewhere sooner or later.
FAST cannot have it both ways. You cannot use this board as a very good source of information about how your product performs in the real world and then decide what you like and do not like.
I am not advocating vendor bashing here at all. I understand that the boards purpose for this is to not allow a board for information turn into a group lynching over things that can be resolved properly.
There is a point though that any business selling anything has a certain responsiblility to make good on the promises of their product.
The fact that you get to hear about problems on this board should not be used as a shield for what I would consider constructive criticism regarding the product you sell. The moderators of this board will not allow any information on here that would be considered damaging.
I dont believe this is either. Time will tell.
If anyone takes issue with what I have said here you can e mail me directly.
Pros
Cons
Software.
