Gary Wells
White turbo Buick trailer park trash
- Mar 2, 2002
and look at what he found:
’87 Turbo-T spare Parts list:
GM Parts:
001: GM P/N 12353801, AC Delco P/N D552, NIB, Coil Pack, qty 2.
002: GM P/N 18018141, AC Delco P/N 179-1237, NIB, switch, brake, kit, qty 2.
003: GM P/N 18038507, AC Delco P/N 18M754, NIB, accumulator asy kit, qty 1.
004: GM P/N 22525555, NIB, handle, shifter, burgundy, has buttons & chrome, qty 1.
005: GM P/N 24503624, AC Delco P/N D1996, NIB, Ignition Module, qty 2.
006: GM P/N 25036663, AC Delco P/N 213-918, Throttle position sensors, NIB, qty 3.
007: GM P/N 25516915, AC Delco P/N 213-143, Sensor, Camshaft, qty 2.
008: GM P/N 25518704, Cap assy, NIB, tri-shield insignia, 2 sets of 4 each set.
009: GM P/N 25519368, AC Delco P/N 214-609, NIB, Valve, asm, Fuel Pressure Reg, qty 1.
010: GM P/N 25523118, AC Delco P/N 15-5320, NIB, asm, valve, heater , qty 3.
011: GM P/N 25525090, Bezel, R/H, NIB, USA made & plated, thick chrome plate, qty 2.
012: GM P/N 25525090, Bezel, R/H, & complete marker asm, driver quality, qty 1.
013: GM P/N 25525091, Bezel, L/H, NIB, USA made & plated, thick chrome plate, qty 2.
014: GM P/N 25526387, Tensioner, drive belt, NIB, qty 3.
015: GM P/N 25526613, ’87 Turbo-T chrome grill, NIB, qty 1.
016: GM P/N 25526984, AC Delco P/N 15-8230, NIB, Relay asm, fan, qty 1.
017: GM P/N 20201221 weather-strip, L/H, NIB, qty 1.
018: GM P/N 25525381, trans mount cat hanger asm, rebui, qty lt by m233roller, qty 1.
019: GM P/N 5936629, Lamp, Parking, GNX, export, clear lens, NIB, qty 1.
020: GM P/N 5936630, Lamp, Parking, GNX, export, clear lens, NIB, qty 1.
Aftermarket Parts:
001: Precision Turbo & Engineering (PT&E) 6262 DBB, “E” configured, NIB.
002: Napa Power-master P/N 390047: Master Cylinder, NIB, complete top to bottom.
003: T/A Perf. Valve covers, wrinkle black, turbo 6 logo, NIB. Includes K&N 62-1040 breathers.
004: GM P/N (N/A), Garrett P/N 1011-144, NIB, waste-gate actuator, 21 PSIG, high boost, qty 1.
005: GM P/N (N/A), Garrett P/N 1011-673, NIB, waste-gate actuator, 16 PSIG, std boost, qty 1.
006: Denso P/N 234-1001, NIB, oxygen sensor.
007: Kirban P/N 7159, GNX center caps, NIB, 1 set (4).
008: Kirban P/N 102063, NIB, Headlight brightener.
009: Kirban P/N 6700, stock steel hood gas shocks.
010: Kirban P/N 6796, vacuum block, 5 port. Qty 2.
011: Kirban P/N 7433, antenna repair kit.
012: Kirban P/N KE003, re-gasket A/C Delco radiator cap.
013: Autometer P/N 4303 vacuum-boost gage, NIB, silver face.
014: Energy Suspension P/N 9.6101R coil spring isolator, NIB.
Parts from my car @ 18K miles:
001: Mike’s (SPOOLFOOL2’s) Kool Kustom turbo cover.
002: Stock ’86-’87 turbo Buick turbo cover. Off my ’87 Turbo-T, almost as new
003: Stock intercooler
004 Stock valve covers
005: Stock dog house
006 Stock starter
007: Stock FPR
008: Stock ignition module
009: Stock coil pack
010: Stock spark plug wires
011: Stock intake system
012: stock up pipes (2).
013: Stock alternator, 2, 1 worked when taken off, 1 needs rebuilding.
Nothing for sale here, just amazed at how much junk I've acquired over the years.
GM Parts:
Aftermarket Parts:
006 Stock starter
007: Stock FPR
