SignUp Now!Are they HOT Hookers or intercooled? If intercooled, any pictures? Thanks.
Pic is up thxI'd be interested if Clusolynn passes and nobody is inline via pm's. Could you post or send pics to superkaz@att.net. Thank you.
Ok thank you. I wonder if these work better on the bigger cube motors? Do you know what size the primaries are?
This may help some. These are race headers and if your engine is stock or mildly built these headers will slow the spool down noticeably. If this is a large displacement engine or built to the hilt then you won't have a problem. Primary is 1.5", cross over and up pipe are 2,25 or 2.5. If you need a good drivers side header then you can shorten the drivers side and get a better than stock header. I used a set of these for experimentation. If you want something for an NA build these would work great.![]()
These headers came off a 87 motorThe headers look exactly like a pair I had on an 85 hotair car, with a different up/down pipes of course. Thanks for the pictures, I'm interested in stock configuration for an 87.
