Back in high school.
We used to wrap chain around our drivers side motor mounts. this was then hooked together with a nut and bolt. Once tightened down, this would make the car shift harder. You could even make some seventeen second cars able to do a second gear chirp.
How about converting your single point distributor, over to duel points.
Indexing your spark plugs to all point to the center of the chamber. Not sure if it helped, but I still do it on the race car.
I've iced intakes or sprayed water on intercoolers / radiators between runs many times.
Before modern sticky tires, you could roll traction compound on your tires to "try" to get them to hook better.
There was the Aqua-Mist water injection for the high compression cars and trucks trying to survive on the "new" unleaded gas of the 1970s.
I do miss seeing velocity stacks sticking out of hoods.
The old saying was, "If you can't make it go fast, CHROME IT".
I still hate chrome on a performance car.
Aaaahhhh the good old days...
Great thread.
Mike Barnard
