Old skool PTE front mount install...search no workey
Steve V
Steve V's Automotive 757 560 2782
Before I drill up this core support I would like to see some pics of an install. I found a link on google but the thread is gone. And searching on here is down.
I have the grill out, am aware that I need to cut the back of it down some. I looks as if the bolts come down from core support on both ends and that's all that holds it. Thanks guys
i dont remove the grille
i put studs into the intercooler, the holes closest to radiator
remove the two 10mm bolts and the clip nuts in rad support and drill the holes just a little bigger
pull out the center header support brace and bend the tab on underside of rad support back
drill out the rivets on the grille extension and remove
use a thin metal plate about 5"x 1" bolted the top inner bumper mounting nut to hold the grille from moving back
slide the IC up , washer and nuts and thats it
