b4black
- May 24, 2001
OK, I just installed a DIY injection system on my TR. The TR is an "Old Style" '83 with a carb/turbo. The alcohol injection is also "Old Style", a low pressure, washer fluid pump spraying just before the carb.
The pump puts out ~30 psi and I bought some water misting nozzles from McMaster (M5, M10, M15). It's sprays a fine mist in the air duct just before the carb. It's switched come on at about 8psi and I'm hoping to run about 15 psi of boost. (I have about $25 into it
I have no idea on how much alcohol to run. I am running 50/50 water/ethanol (denatured). I have a 10 led knock gauge and an EGT gauge (that I'm not too familiar with yet). I also have boost timing retard I can work with.
Any advice to get me started? Thanks.
