? on a boost controller
leprcon
I love burnouts
do u really need a boost controller? lets say u adjust the rod out 2 where u need and thats what u want is there a advantage other than adjustability? or does it help with lag:frown: because i dont have one currently
Technically it should help with the lag, because the boost controller is keeping the boost signal from reaching the wastegate actuator, therefore, it is keeping the wastegate puck assembly closed longer which should help with transient response. IE keeps the turbine wheel spinning faster until exhaust is diverted away by virtue of the wastegate pushing the puck open. Exactly how much it helps no one really knows, but I don't think it would help someone with say a stock converter spool up a GT-Q equipped turbo. But it should move the torque band a little lower in the RPM range because boost would be made sooner. I don't think there has been any test results as of yet, but it could be as simple as dynoing a car without one with the boost set at level A, then installing the boost controller, leaving the boost at level A and retesting. The dyno graph would verify the transient response via torque readings. Or if you could data log boost with a FAST or XFI, that would verify it too.
It should help the turbo spool faster. Think about it like this, under normal operation, the wastegate actuator sees boost pressure as soon as you go WOT, this starts the actuation process and immediately slightly cracks the puck open from the face of the turbine housing. This starts the control/slowing of the turbine wheel, once the set spring rate is reached, the valve would be fully opened and turbine wheel speed should be stabilized / controlled.
HTH a little.
Patrick
well i have a pecision 76 with a .83 housing and it is a dog off the linei have a 3400 stall 9/11 pts converter any thoughts?
It might help you a little, but for starters, you don't have enough converter for your turbo. Having the converter loosened up to 3800-4000 would fix your lag. I seriously doubt the boost control valve will help that much. It's a known fact that the PT76 with a GT-Q turbine wheel on a PTE .85 A/R 3-bolt turbine housing needs at least a 3800 flash stall converter to make it spool decently.
Escpeically on a 231-235ci v6. If it were me, I'd loosen the converter.
HTH
Patrick
thank u i was thinking about a 4000 stall so u have assured me i am going in the right direction looks like i am going 2 pull it and send it 2 bruce thank u very much for your help :cool:
