turbocliff
I Slang in my white T
- Jul 5, 2004
fresh 153 block ON CENTER stage II motor ready to run.
153 block
aluminum BMS stage II heads
T&D shaft rockers
solid roller cam
MSD distributor set up for sequential EFI
ATR Stainless headers
PT88 turbo
4" to 3.5" downpipe and cat back exhaust with vibrant performance muffler
BA Front mount intercooler
Whites racing front cover with oil pump
Carb intake with fuel rails, 160# injectors, wilson elbow, and 90mm TB
RJC deep pan with -10 return from turbo and -12 feed to oil pump
Mezier electric water pump
Kryptonite crank - carillo rod - je piston
Cometic head gaskets
JW flywheel
BMS hub
Stock crank trigger sensor
Aeromotive regulator
I also have a dry sump set up for this motor with pan, front cover, gear drive, etc.
May consider trades, price is $11,000.00 OBO
Also have that can be sold with motor:
AMS1000
XFI
DRCTH400 trans with reverse pattern valve body, brake, and ultrabell
PTC Converter
Weldon pump
MSD 7AL2 with HVCII coil, adjustable two step module, etc.
Motor is sitting in car right now, was installed but not fired in the fall. Located in Bolingbrook, IL
153 block
T&D shaft rockers
solid roller cam
PT88 turbo
JW flywheel
BMS hub
AMS1000
XFI
PTC Converter
Weldon pump
