One pump or Two?
jpratt
I am going to run a TA49, 42.5, THDP, R.A Volt boster, Street chip with 93 oct. MY question is ? Will a Walbro 340 fuel pump be adequate or do I need two of them? Either way they will be hotwired. I will run mostly as a daily driver and a few times at the track. I am just getting done with having the motor redone. New crank, cam, replaced a burnt piston, replaced a spun conn rod.
Single 340....
took me safely to 10.80 @ 126 mph. With your combo, you will never need more fuel pump than the 340 hotwired.
hth....
