Just bought this car and was wondering about what the operating range was. It's not a roller so I don't know if it's much different than stock (rpm wise)
I plan on getting a Dutt neck, a budget down pipe and test pipe from Kirbans and a quality scan tool for data logging..
Mods are as follows.
Engine: has about 5k since freshened up
Comp cam 208: all the info I have on the cam.
Comp lifters
APR Main and Head Studs
HP Rod, Cam and Main Bearings
Valve Job
Resurfaced Heads
Honed Cylinders
Rebuilt Stock Turbo from Precision
Runs 20lbs of Boost WOT
340 Walbro Fuel Pump w/ Hot wire Kit
Hoping to get it down in the 12.0 range once it's dialed in. Was able to run 12.20 on my previous 86-T on 20psi and 28" tall slicks with a similar combo minus the cam. Think with the cam I'd be better off on 26 or 27" tire?
Been away From TR's for 5 yrs FNG around with this GTO
Thanks.
Comp lifters
Valve Job
Resurfaced Heads
Honed Cylinders
Thanks.
