SignUp Now!That's strange as I've had to bags 2 bags in my car and no leakage . Like stated before it does help with more then just clearance it will also help with hard launchesI've used airbags before. Always seem to lose air. Looking for a more permanent fix.
Coilovers are the only way to go in my mind, You can set your ride height exactly where you want it, adjust it if weight is added to the car, adjust it for taller tires (slicks) without worrying about bags that change the rate of the springs and changes the ride quality. With coil overs no matter where the car is set it will always ride nice!Rear sags a bit. Don't know if its from the subwoofers or worn springs. Do I need coil overs? Ride Tech looks a bit pricey. How about QA1 or Hotchkis? Would also like a smooth ride and simple installation. Not into autocrossing. Thanks.
did you have to cut off the old perches off and weld these in?you say 28" with a cc627 but there are many variables like tire height /tire pressure /weight to expect similar results
what i can guarantee him is if he is going to be happy with 1" more than he has now that a 1" spacer will put him there
if he needs more they sell them in 1/2 increments (1", 1.5, 2") to get him where he wants
another more permanent adjustable option that i use on my cars for the track is weld in adjustable spring perches from wolferaceraft that allow you to dial the spring height as you would with a coilover shock and run coilover springs that you can buy based on weight and at various heights . With fiberglass bumper + battery in trunk i run a 12"-150# spring with the adjuster set about 1/2 off the bottom to tuck a 28" tire into the fender (26.5 ride height ), if i want more height i can just spin them up
