Otc 2000
VernLee
Hi , anyone using a otc 2000 ? I just bought one off e-bay, Yep !
got screwed, doesn't work, I sent it in today to otc hoping I can get it fixed with out spending a fortune. I was wondering what
users thought of it ? how hard is it to operate ? any opinions ?
Vern Lee
An OTC 2000 is very old school tool and will show only two parameters at a time, but I am old school and it is what I use. I purchased one early last year and I’m still learning how to use it. I use it as a live & recording tool on my 87 GN. It can be used to set TPS, IACs, view converter lock-up, 02 CC, 02 volts etc. I attach it to the dash with adhesive Velcro strips when racing and set the mode to knock (displays No or Yes) mode. After recording a ¼ mile pass in road mode all the parameters can be viewed by calling up each mode and viewing the recorded frames. It is a handy tool but cannot compare to Direct Scan and other programs. It would probably be a good idea to monitor exhaust gas temps with an EGT analyzer also. They are not that hard to use if you have a manual. You can view the modes for it at gnttype.org. Just plug it in and turn the key on and tinker with it, you will get the hang of it. If you do not have an owner’s manual they can often be found on E-Bay. Looking at your mod that you have listed I would reccomend new school scanner to protect your investment.
Hope this helps some
87 GN: Stock turbo, Stock Intercooler, Down Pipe, Injectors etc. Mods are: Removed Cat / Installed Dump Tube, Eric Marshall Chip, Adjustable FPR, BFG 275/50/15 Drag Radials, Pass Air Bag @ 20 lbs, New Valve Springs, 160 Thermostat, Racing Gas, Walbro 340 Pump, S-10 Wheel Cylinders, K&N Replacement Filter, RJC Boost Controller & Aftermarket Boost Gauge. Best E. T. 12.57 @ 107.41
