ok guys need help i dont know wats going on i get the system on and going ok i punch in mode 01 which on the mode list is for rpm/battery voltage but it only shows rpm how do i get to the battery voltage reading as it also is mode 01 ? or even if i punch in 08 its so soppose to display rpm/TPS according to the mode list but it only shows rpm? the other thing most important to me now is i really have been wanting to adjust my tps and iac the problem is wen i go to punch mode 26 iac counts or 41 tps it says unused ? y does it do that how am i soppose to adjust wen i cant get these 2 readings? any help
Do you have the instruction manual for the 2000?If you don't, I have an extra copy let me know if you wan't it.Jake
