Outside Door Handle and Door Lock Trim Replacment
jpwahler
Good morning guys,
I'm trying to freshen the exterior of the car for show season. Instead of breaking something first, I thought I would ask if anyone knows how to remove the exterior door handle and door lock trim for replacement? I looked for some previous threads but no luck.
Thanks!
locks
Hope this can help theres a u shape clip that holds the key lock in place and for the door handle its two 10mm nuts that hold that on with a back up plate on the inside you have to watch there is one rod hook up two the door handle make sure you take a good look because it is tricky. the rod that is clip to the door handle pushes down on the lach that opens the door from the keeper good luck.
I just took mine out to get ready for paint.....took a few pics so I can see how it all goes back together.
