Overdrive Internal Gear Splines
buickboy
Mark or Bruce-
While i am getting all internals ready for reassembly i was inspecting the inner hub splines of the overdrive internal gear and they have been slightly deformed by the shaft splines. I sheared a drum shaft and will be installing Bruces Roller package when it goes back together. need to know if the spline deformation is anything to worry about. Do they strip out eventually. Sorry no picture to show. I am sure you guys have seen this. Advice please.
thanks,
Mitch
You should replace and the billet forward drum will wear the splines on the ring gear.
Thanks for the response Lonnie. I picked up a used internal gear from a local shop for $20.
Mitch
