Tfreestyle
- May 24, 2007
quick rundown...
-Idling to charge battery
-12-15 minutes later came to car and smoke coming from under hood, I shut it off immediately. Coolant gushing from overflow tank.
-temp somewhere in the 230-240 range, not sure, didnt look at the gauge close enough unfortunately
-will restart easily but losing oil pressure at idle, holds pressure fine at higher rpms
-oil pressure at idle before the incident was around 20psi
Full story...
Well today was a horrible day. After two years of restoring my GN I finally painted it yesterday(I did start it every few weeks to move in the primer booth or just to run it). Today I had it running on the lift charging up the battery, I stepped outside for a phone call, I come back to smoke coming from under the hood. I ran over and shut the car off. I glimpsed at the temp gauge, it was in the 230 or so range I think but I had run to under the hood to see what was happening. The Coolant was gushing out of the overflow tank, it was everywhere, hugeeee like lake under the car.
The car was maybe running 12-15 minutes. About 20minutes later I try restarting the car to see what was going on, it started right up no problem but now the oil pressure will drop quickly to just a few psi at idle. I had a friend come over and we started it up again 20 minutes later, got the idle up to about 2000-2500 rpms and the pressure seemed right, 25-30ish psi. We didnt let it run for more then about 45 seconds just in case. I wanted to start it again after it completely cooled down but the battery was dead(has a bad battery) when I went back 2 hours later so I couldnt check again.
Checked oil and it looked fine, no oil/coolant cocktail. Im thinking the coolant overflow was caused by a stuck thermostat but havent had a chance to looking into it, im worried more about the low oil pressure. The engine only has maybe 2-3k miles on it, had it rebuilt at gn1 performance a few years back, used it as a daily driver for about 3 months and just a few drives here and there til I ripped it apart for restoration.
Any ideas on the low oil pressure? Im sure it can be a number of things, any tips on what to check first?
Full story...
