Hi gang,
I've read the sticky and went to the site there..had a couple questions.
when i read "hot loaded" am i correct in assuming this means fully assmebled section with the good stuff or am i way off base here??
also as far as a basic overhaul kit is concerned, bushings,steels ,frictions and seals does anyone out there sell one with the better frictions, cause i like the idea of the alto? band was it? and the others suggested on the sticky post..
as far as hard parts are concerned would have to way that out considering my finacial situation.
however have seen a roller clutch in pieces throughout one of my trannys
so that would be a new piece involved
i have a brf that needs rebiuld suposedly lost second gear so anything particular i should look into when i start this,or just go through the overhaul step by step?
thanks
Chris Pacheco
WE287GN
thanks
Chris Pacheco
WE287GN
