Overrun clutch valve assembly
TT/Ameasap
The White Blur
Which one is it?
Also. I have three check balls. 2 of them are .250 and 1 is .380 .....Where do they go? When I pulled them out, I thought they were all the same size, but now I cant remember where each one went.
Any help is appreciated. Kinda in a hurry.
Does it have a kit? All mine came out the same size, but I don't think anyone has been in there since the factory put it together. Instructions for the kit have any insight?
case side
vb side
I'm guessing it is one of these above. Look at your separator plate and match up the holes and look for the hole that is bigger than the others that looks like a bigger ball was used there.
thanks
Any idea where this goes??? It fell out just before I put the pan back on.
:eek: That's your manual valve link. Without that, the shifter in the car has no control over the transmission ranges. Time to pull the valve body down again.
You gotta be kidding me. Where does it go then?
And do I have to take the seperator plate off....that was a pain
