P/S delete
Robert
Does anyone out there know if someone is fabricating a unit to replace the P/S pump & maintain the stock serpentine belt cconfiguration. I'm working on a project that will not require P/S & I'd like to replace the pump with something that is a bolt in. This is for a '87 GN motor.
If you want to run AC then you will have to fab up something. If you are running AC delete then Champion Racing Heads makes an awesome bracket that relocates the alternator down low.
