FiveOhSlow
- Nov 17, 2004
I'm running Razor's PAC (meth) in my TR. a bit ago I started having a knock problem, where over approx. 10lbs of boost, my knock reading would rapidly increase as I increased throttle/boost. I could barely touch the throttle without my knock gauge and scanmaster showing 6-12KR (I always quickly let off). When I hit the pump primer button, I could hear the high pitched tone the pump has always made, and all the lights and indicators were working fine as it was when the alcohol was injecting normally before.
With the car off, I took off my inlet tube with the nozzle in it and pressed the pump primer button for quite awhile, pump made noise but no alcohol came out. The pump is getting just under 12v on the red wire going into the pump. Everything looks normal. Why am I not getting any methanol injected?
thanks
thanks
