Fiberglass
Preparing, Priming and Painting Fiberglass Parts
It is preferable to apply a two-part epoxy primer prior to painting your fiberglass parts. There are several epoxy primers that can be used with excellent results. If you fail to use a good epoxy primer before applying your finish color paint, the finish paint will probably not last very long, peeling off of the fiberglass long before you think it should. In some quarters, knowledgeable fiberglass fabricators also believe that some color coat painting systems tend to deteriorate and damage the underlying fiberglass materials. In this section, we hope to demonstrate the proper way to prepare your fiberglass parts for painting.
Some of the fiberglass parts you may elect to add to your Challenger include the nosecone, Hoerner wing tips, wheel pants, and gap covers. Work needing to be done to the unfinished fiberglass parts may include cutting, triming, drilling, filling, filing, and sanding.
The following list contains some of the items you will need:
A rasp or Bastard file
A portable electric drill and drill bits
An electric grinder
A painting respirator
320 & 400 grit wet or dry sandpaper
"Super fil" epoxy filler
A suitable paint prep cleaning solution
Two-part Epoxy primer paint
Color coat system (paint and thinner)
Starting With Unfinished Fiberglass Parts
Cutting, Drilling, Filing and Sanding Before you start painting your fiberglass parts, a certain amount of preparation is necessary. Parts must first be fitted to the airframe. This usually requires some trimming, drilling of mounting holes and, in the case of the nosecone, you must also cut out the hole for the front landing gear leg.
Another area which requires work is the seam joining the two shell halves along the top center of the wheel pants. When the two halves are joined at the factory, the resulting seam leaves a 3/16" raised ridge along the joint. The best way to remove this ridge is with a rasp or Bastard file. You will want to bring this ridge down to the same level as the surounding surface. You may encounter (expose) air bubbles in the bonding area of the two halves. These can be filled with "Super Fil", a two-part epoxy aircraft filler. When the Super Fil epoxy has completely dried, sand it down with 320 grit sandpaper until filled areas are flush and smooth with the pant surface. Then continue to sand the entire joining seam to even out and remove any file marks. Finish off by "wet sanding" the entire pant outside surface with 400 grit Wet or Dry sandpaper. Prior to applying epoxy primer, clean the sanded surfaces with your chosen paint prep cleaner.
Before painting fiberglass surfaces, you need to first "slightly" scratch these surfaces with 320 grit sandpaper, used dry. This will facilitate a better bonding surface for the primer to adhere to. These surfaces must then be cleaned with a suitable paint prep cleaning solution prior to painting with the primmer. This is an "ABSOLUTE MUST".
Painting Fiberglass With A Two-Part Epoxy Paint When painting any fiberglass surface, it is "VERY IMPORTANT" to completely clean the fiberglass surface prior to painting. In the photo to the right, you will see round spots in the paint surface. This was caused from contamination of the fiberglass surface prior to painting.
In this case, a white epoxy paint was selected as it will be less intrusive when painting over it with your finish paint color.
Mixing a two-part epoxy paint will vary, depending on what brand you choose. Therefore, you will need to follow the manufacturers instructions for mixing the base and catylist. After mixing your paint and after thoroughly cleaning the fiberglass parts, you will apply to each fiberglass part three coats, using a cross pattern for each. Allow each coat to dry completely before applying the next coat...
Sal good luck you ought to be able to yourself. ROC 87 on here is a very good painter does his own stuff in the garage. If you drop him a PM he would be more then happy to give you some tips. Now if you don't want to mess with it, and If the 100 dollar guys "PREP" your bumpers right(you don't want em' to peel with 1st high pressure car wash) I'd go with the 100 dollar guys(does that include paint or is that just labor?if that includes everything go with them for sure..) just let bumpers dry good you don't need em' baked for an extra 80-100 bucks. Like you said it ain't a show car
