i will be parting out:
all parts are in great or good condition
first off,the motor and drive train,ect
1987 buick GN:
PARTING OUT:
1987 BUICK “HEAVY MODDED” GRAND NATIONAL
REBUILT (8K) “109” SHORTBLOCK
WISECO FORGED PISTONS, J.E LIGHT WEIGHT PINS
TREATED RODS
TURNED CRANK 20’
ARP EQUIPPED
COMP 212/212 FLAT TAPPED CAM
COMP LIFTERS
BALANCE AND BLUE PRINTED BY FAERMAN RACING ENGINES/HOUSTON TX
GM TIMING COVER
RJC OIL BIGGIE ADAPTER
$1,850
Duttweiller iron stage III ported heads
Fresh and recently fluxed
100# comp springs
Larger valves
Gm stock rockers, RJC solid shaft
Flowed 240 cfm
Nice heads!!!!!!
$850
Stock buick lower intake/kenne bell upper polish plenum
Cleaned and in good condition
$250
Kenne bell polish 70mm throttle body
Good condition
$190
Kenne bell fuel regulator
Good working condition
With factory fuel rails
$150
Msd 50 lb injector
Recently cleaned and flowed
$200
Nick micale modified 3 core radiator
Recently flushed for leaks
Best radiator up to date,kept my car cool @ 175 all day!!
$275
Update 1/6/07
87 buick turbo factory headers
Good condition
Passenger header recently fixed for cracking
$120
Terry Houston 3 in down internal DP.
Good condition
$300
Conleys performance 3 in dual full exhaust
Good condition,no rust! 2 yr old
$280
Stock coil and module
1 yr old
Gm product
$100
Jacob race wires
8.5 mm
Like new
$30
Single electric fan
Worked great!
$50
CAS v4 stock location 23 row intercooler
Has small hit on the bottom
Does not leak however
Black
$230
Hoses and clamps
$25
200amp alternator with volt regulator
$250
Gm direct sterring pump and hoses :
Good condition
$100
Gm direct full working AC of the GN
Everything worked great
Needs to recharge due to unistalling off my car
Great for converting back to stock!!!
$380
Innovative t-70 BB turbo
No slack no play
Spooled was the best!!!
Ceramic coated
Arp bolted compressor
63/ exhaust housing
$950
Buick chrome turbo inlet tube
$40
Buick 3in Conley performance gloss black maf pipe
$40
Gm direct modified 3 in mass air meter
6 months old
$100
Buick log 6 tall valve covers
$140
Art carr 3200 NL 9 in. billet stall
1 yr old.
Great condition!
$550
Art carr built 200r4 tranny with red line internals
Right step transbrake
Bad ass tranny!!!
$1500
Gm direct driveshaft
Stock
$100
1987 buick GN:
PARTING OUT:
TREATED RODS
TURNED CRANK 20’
ARP EQUIPPED
COMP LIFTERS
GM TIMING COVER
$1,850
100# comp springs
Larger valves
Flowed 240 cfm
Nice heads!!!!!!
$850
$250
Good condition
$190
$150
Msd 50 lb injector
$200
$275
Update 1/6/07
Good condition
$120
Good condition
$300
$280
1 yr old
Gm product
$100
Jacob race wires
8.5 mm
Like new
$30
Single electric fan
Worked great!
$50
Black
$230
Hoses and clamps
$25
$250
Good condition
$100
$380
No slack no play
Ceramic coated
63/ exhaust housing
$950
$40
$40
6 months old
$100
$140
1 yr old.
Great condition!
$550
Bad ass tranny!!!
$1500
Stock
$100
