278cikiller
- Dec 21, 2007
One set of doors in very nice shape no rust $300.00 for the pair these are power windows and locks.
One passenger door no rust at all in excellent shape $250.00 with power locks and window
hard top head liner just redone same coulor has G/N $250.00-- WILL NOT SHIP
front filers in excellent shape no cracks need repaint $150.00
rear fillers in excellent shape the same has above $150.00
I also have some interior panels that are gray in coulor let me know what you need.
left and right drip rails in crome $40.00 for the pair
bottom crome cowl for the windshield no rust in excellent shape $60.00---- WILL NOT SHIP
hard top roof you cut $250.00
86 G/N grill crome no chips or cracks $100.00
86 buick regal grill crome no cracks or chips $60.00
left and right fennders no rust $50.00 each
inside fenders $40.00 each
rear 1/4 panels you cut no rust $75.00 each
Three bolt to four bolt adaptor for stock headers $50.00
wiring harness needs two or three plug ends but the rest is all there $200.00 or best ofter
I also have lots of crome parts that can be panited let me know what you need
front and rear seat belt in nice shape $150.00 a set.
front and rear bumbers in crome $100.00 or best ofter---- will not ship
4 cragger rims 5 bolt 14" rims with good tires $150.00 for all four
one set of G/N headers with cross over with two delta gates these headers were on my stage II motor they will support well over 700hp or more $350 for the set
two vaccum brake systems with peadels no vaccum blocks $150.00 each
Front and back wheel well mouldings crome no dings no rust in Excellent shape $175.00.
I wil crate any big parts for free.
All parts you know are plus the ride or just call NATIONAL RACING thanks Dan I can send pics of parts.
__________________
1987 BUICK REGAL SLEEPER 274-done 45 over stage II motor, # 153 BLOCK , 212 ,206 roller cam, Preission Front mount intercooler, 83lb injectors,stock ECM with Drivers,-RJC-4" crome pipe,-3-1/2" LS-1 MASS AIR, Preission 70MM Dog House and power plate, 70mm Accufab Throttle Body, Quad air, Double Fuel Pump, G&N-1 Alum Heads, 1.65 T&D Roller Rockers, NEW SET OF STAINLESS STEEL ATR HEADERS FOUR BOLT,WITH MARK II RACE GATE, SMC Alcohol injection system, John Craig LImted Enginering Big Shaft 76 Turbo with .81 EXCH Housing 3" mandrel bent exhaust front to back, Raised runners on intake & 1" inch spacer, Power plate, FORD 9" REAR END WITH 390 GEARS WITH 33 SPLINE AXELS:AIR BAGS AND DRAG SHOCKS.
NATIONAL RACING:6 24/7 SERVICE.:905-213-2871 or 905-419-0704
Home of Durhams Fastest Turbo Buicks:
I DO WORK ON GRAND NATIONALS,AND T-TYPES & GNX.
22 YEARS ON THESE CARS.
I DO SAND BLASTING NOW!
ERICS TURBO TWEEK CHIP.
I DO HAVE A CAR TRAILER AND TRUCK FOR FLOAT SERVICE
__________________
