Hi,
If still available. I would like to buy.
1-Charcoal Canister w/ Purge Solenoid
2-Stock breather and tube
Would you take 25.00 shipped? For both
Thanks, Mike
Hi Mike- Please send me your zip code...
SignUp Now!Hi,
Thanks, Mike
18974 PA
Sent PMI sent you a PM...
Sent PM
GN Parts for Sale in NJ (08081)
All parts are from an 87 GN & are used unless otherwise noted.
- Stock turbo (no end play) $100
- Turbo oil drain $20
- Stock oil cooler lines $25
- Heater control valve $15
- EGR solenoid on bracket $10
- EGR valve bracket $5
- Coolant sensor 2 wire (NOS GM) $25
- Coolant sensor 2 wire (New Aftermarket) $10
- Coolant sensor 1 wire (New) $20
- Crank sensor (no bracket) $20
- Tensioner pulley w/bearing (NOS GM) $30
- Power steering pump pulley $10
- Water pump pulley $10
- Alternator pulley and fan (power coated) $35
- Stock rocker shaft and arms (2) $30
- Power steering return line $5
- Kirban plug wires (like new) $30
- Stock Electric Fan (no harness) $35
If you don't like my prices, feel free to make me an offer & I'm also up for bundling discounts.
Thanks for looking...
Updated
Updated
Updated
Arrived today. Bump for a good seller.Thanks Scott - The turbo drain tube will be on its way to you soon...
