Parts needed to go low tens reliable
GNDriven
If anyone has any of these please PM me.
1. Aluminum heads newer casting.
2. 30 something spline posi differential
3. 30 somthing spline axels
4. Rear sway bar
5. QA1 or Koni Shocks
6. 3.5" Aluminum drive shaft w/ 1350 yokes
7. 1350 pinion yoke
8. Fiberglass rear bumper
There is a good combo in the for sale section.
heads/intake
Just a little food for thought. you don't need aluminum heads to runs low 10's. Ported irons will get you well into the 9's. With the coin you save, you could add somewhere else to complement your setup. I do have a 70GTQ turbo forsale if your interested that would also help you out. Good luck with your project.
You are right there are lots of people going fast on Irons. However, I am wanting to go 10.00s on an alcohol tune of 25-26 PSI, and a 1.60 short time. Street style numbers, this means lots of MPH.
Engine combo is built stoke stroked 109, CAT crank, k1rods, JE pistons. I have now a set of Champion Irons and matching lower intake. Target engine RPM operating range is 3.5k to 6.2k. Cam is 215/220 roller, Turbo is BBT72Qtrim Turbonetics.
Hey if you see something not right in my combo let me hear about it. Please no opinions, either real world experience or math/physics.
I need to calculate the volumetric efficiency numbers. But I think I would need to run 28+ psi to do it on IRONS.
If some engine math guru wants to put of some numbers I would appreciate it.
Bump,
Still looking for parts stated above.
Anyone have an Eaton 30spline posi or anykind of built rear parts?
I have like new 30 spline moser [C clip} with 1/2 long studs,open carrier with
auburn mini spool works great maybe 50 street miles and no track passes.I'm going to chuck my stock stuff back in not planning on racing for a long time
I'll let it go for $350 plus shipping I'm near Atlanta maybe not too expensive to ship to gulf coast.
I have a set of M&A aluminium heads for sale complete with 1 year old Crane gold rockers, polished and powdercoated valve covers and port matched intake manifold. "pm" me if interested...
thanks,
Claude.
Parts that I need are
1. Aluminum heads newest casting. Done
3. 30 somthing spline axels Done
4. Rear sway bar
7. 1350 pinion yoke
9.HnR parts passenger motor mount
10. TH400 trans mount
11.TH400 converter
12. Frame notch kit
Please PM me..
