Parts-Parts-Parts For Sale
TurboMonte 2
Car Nut
I've sold my 87 GN and now have many parts to "part-with"...All parts are good used condition for 86/7 TurboBuick, unless specified otherwise...All prices are without shipping included & will ship to continental US only...
Paypal or Money Order preferred payment...Thanks in advance for looking!
ENGINE:
SMC Alky Kit, single M-15 nozzle, rectangular tank (pump inside), non-progressive--$165
TurboTweak 93+Alky Chip for 60-65# injectors--$50
62mm ported stock throttle body, no shaft wobble--$65
64mm hand-ported upper intake plenum (doghouse)--$40
62mm throttle body gasket kit, New--$8
Plenum + Vac block Gaskets, New--$6
Stock Throttle body with sensors--$45
Tomco TPS-New-In-Box, hereafter shown as N-I-B--$16
3" LT1 MAF sensor, screen--$50
3" LT1 MAF sensor, no screen (I noticed no diff in performance)--$40
3" Cyclone FuelSaver ("Tornado"), used by many @ turbo inlet to eliminate surge--$20
Stock Intercooler (IC)--$60
Stock IC mounting bracket, driver side--$12
Stock IC hoses, 2"x2" convoluted in, 2.5" out--$10
Cooling Fan/Shroud, no ballast resistor--$60
AC Delco Fuel pump relay, N-I-B--$20
New-design (warranty-replacement) Walbro F 20000169 Fuel Pump-N-I-B--$70
Painted relay cover (black)--planned to modify/fit over Dr side relays--$12
Denso 234-1001 O2 sensor, N-I-B--$15
HD adjustable Wastegate controller--$55
2--160 Deg Thermostats-New--$10 each
1--180 Deg Thermostat--$6
GP Sorensen Crank Sensor-N-I-B--$22
2--Cam Sensors w/ cap & plug--$65 each
1--Cam Sensor, cap & plug only--$25
1--Cam Sensor, cap & plug only-New--$40
3--87 GM Coil-Pack + ICM Module + mounting plate--$80 each
2--"Like-New" Coil-Packs, used for testing only--$40
ESC Module--$25
2--Everco Coolant Temp Sensor N-I-B--$13
EGR Valve + hold-down brkt + cover
ACCEL 8.8 Ferro-spiral race plug wires, set of 6, black--$20
RED Armstrong 8mm Hi-Perf Silicone Mag-Core Supression plug wires, New--$30
Wastegate Solenoid-N-I-B--$45
Wastegate Solenoid, like-new--$30
BstC Boost Controller--$60
Approx 24k miles on parts listed immed. below:
6--Keith Black Hypereutectic pistons, +0.030, w/ rings & wrist pins--$60
12--Pushrods--$10
Water Pump--$15
Stock MAF Turbo Inlet hose, v good cond'n, 3/4" of a wire exposed (outside only-rub alt'r)--$20
2--PCV valves (CV893C)-N-I-B--$7 each
Engine Tq Hold-down "turnbuckle" (metal)--$5
Stock Oil-Fill Neck, paint chipped on neck--$7
INTERIOR/INSTRUMENTATION:
Pr. SunVisors w/ rod/brackets, lighted passenger, need recovering--$15
Steering wheel, worn @ top--$45
Steering Wheel center ring--$20
Horn Button/Pad w/ "T-Type" medallion installed + add'l "T" center medal'n--$30
Horn Button/Pad w/ Buick Tri-shield medallion installed--$25
Early GN Steering Wheel, needs refinishing--$30
Stock, grey Drvrs side A-Pillar Trim--$15
Pr seat belt clips, grey--$15
GM door-pull screw covers (4), brushed aluminum, N-I-B--$16
Power Seat Assembly (the good 87 one w/ 3 separate motors, switch + trim panels--$95
Casper's Audible Knock Detector/Alarm, N-I-B--$45
Lotek 3-gauge A-pillar Pod, N-I-B w/ screws/covers--$45
2-gauge Pod for Console, gray--$20
2-Gauge Dash Panel, Aluminum, "Buick Motorsports" logo--$30
VDO Cockpit Series Oil Temp gauge (2-1/16") w/ light & sensor,100-300 deg F, blk face--$30
VDO cockpit Series 0-30 psi boost gauge (2-1/16") w/ light, black face--$20
VDO Cockpit Series 30" Vac to 25 psi boost gauge (2-1/16") w/ light & install kit, white face--$30
EGT gauge (2-1/16") w/ probe, blk face--$45
Air/Fuel ratio LED-lighted gauge (2-1/16"), takes signal off O2 sensor--$25
ECM-Computer, #1227148, no chips--$55
ECM-Computer, #1226459, both chips--stock appearing, (Hot-Air app'n?)--$45
That's all I can list now--falling asleep...
I'll list MORE PARTS over next several days for
ACCESSORIES:, and
EXTERIOR/ CHASSIS categories
Thanks again for looking,,, Monte
I will take these two items....Do you have the hose to connect two solenoids together for the BstC Boost Controller?
Thanks, Bill
Hi There,
Will you send me a price shipped to Newmarket, Ontario, L3X-3A7 and your paypal address please.
Thanks so much,
NK!!
I'll take this assuming it is aset of 6:
Take this also:
Also I'll take this if it is the plastic ring that holds the horn pad:
"ACCEL 8.8 Ferro-spiral race plug wires, set of 6, black--$20" are this cut for the lc2 motor and what condition are they in
Ill take this:
Thanks, Bill
Sorry, I have neither the hoses nor knowledge of the dual solenoid hookup,,,Monte
parts
Monte
I'll take these items
ESC Module--$25
Total $205
Can you bring these to autofair and i pick them up.
that will be in a couple of weeks
Thanks pat
I'll take these.
PM me your Paypal addy.
Roger
Boost Gauge
Sent PM
Hi There,
Thanks so much,
NK!!
Sorry, nothing personal--but as stated @ beginning of my ad, I'm shipping to continental U.S. only...Tks for looking,,, Monte
