- Feb 18, 2006
What is everyone using for a PCV valve or valve system.I had an ATR valve inline of the stock PCV and found it did not work well at idle.Breathers seemed to mist a little.I am looking at a change,maybe the RJC piece.Any thoughts?
Kevin![]()
Kev,
Sorry things got a little of topic. I get worked up sometimes on this stuff. :redface:
A good working pcv does the same thing as a inline check valve. They are easy to test by simply blowing through it. Air should only flow through one way and seal the other way. Just like a check valve.
Some pcv's will leak a very small amount when blowing through the opposite way. Not a real big deal. As long as it seals 90% your good.
If you have a good working pcv and you are still getting vapors out the vc breathers @ idle, you may have other problems.
The atr valves don't last very long before they start to hang up.You can take it off and clean it with some brake cleaner and maybe get it to work again but prolly won't last too long.
