I was wondering if anyone happens to know what the original pedal on the powermater pedals were.
I have heard alot of people saying to swap over to the vacuum style brake pedal and then use the upper mounting hole.
Secondly, from what i know, you want to have the pushrod as parallel to the master cylinder bore as possible so that the piston will not stick inside the master cylinder. Now if you relocate the pin height for added pedal ratio, you will they be throwing off the angel of te pushrod? is that correct?
Help Anyone? Will could you share some light on the subject seeing as you recently went through the swap.
Adrian
Adrian
