Peg legger 1/4 mile times please
Little6pack
Can those of you that own or have owned peg legger GN's
list your 1/4 mile times from past or present.
Also if stock or any mods.
My Hot air car has gone a best of 13.98 at 95. The mods the car had at the time were, Race Gas, 20 P.S.I Boost, Lockup Convertor, and slicks. My best 60' time in car is a 1.87. Of course I had slicks but the car never had a problem hooking.
Andrew
Dman33 used to run 7.60's in the 1/8th mile (12.0s) with his pegleg. TE44 turbo I think. He'd crank 40 psi of air in the right side airbag and leave off the ebrake on 26 X 10 slicks.
My 85 ran 12.0's with 2.1x 60' times on a pegleg, and a set of nitto dr's.
Never got it to run faster.... :P
My 86 GN went 12.88@106 with a 1.77 60', peg leg, stock except filter, pump, chip, racegas and slicks. I launched at 5, 10 and 15psi and the 60' would go no lower...
My car has a posi but the clutches are burnt up so it only spins the back right when I have the slicks on. Main mods are ported heads, 50's, 63, 3200 stall, .30 over JE's , ESP FMIC. Alot more but dont wanna type it all I have ran alot of 7's in the 1/8th. Fastest being a 7.21 @ 96 mph. On 28x9 slicks. 20 psi boost.
