pics: as-cast GN1's and Felpro 1400's
BEATAV8
The Engine Whisperer
Are these gaskets going to work out OK? Should I match a stock gasket instead?
Intake manifold is a ported stocker from champion, which should match relatively well to the as-cast cylinder head ports. Just don't know if the over sized gasket would cause a flow problem.
How does it match up with the intake? I'm no expert but I would at least gasket match them. But, thats just my .02
I Don't See A Problem With The Oversize Gasket But It Would Be Nice If It Was Matched To It.
the intake is a ported stocker. should match fairly well to the heads
You might want to check. Here's what my stuff looks like (GN1s and stock Champion intake).
That's about what I'm expecting. Are you going to re-work or just let it slide?
I will post some more pics with a stock type intake gasket soon.
Stock gasket has been ever so slightly modified at the top... could use a little bit more.
just realized I titled the thread 1400's when I showed a pic of 1200's. I'm a doofis!:redface:
No re-work here. The intake was ported too much, I would have to port the heads.
